How to host an already built flatpak application
Hello,
I have an open source app packaged as a flatpak package using BuildStream. Last time I asked, it wasn’t possible to use flathub to build flatpak apps using BuildStream. If it is still the case, can I sync my ostree repo hosted elsewere with flathub ? Should I use extra-data for this purpose ?
Thank you very much for your help.
The solution I found to my problem was to export the flatpak app content to a tarball stored on Gitlab Pages like this :
ostree checkout -U --repo=public/flatpak app/com.gitlab.inendi.Inspector/x86_64/main public/flatpak_app && cd public/flatpak_app && tar -I lbzip2 -cf "$CI_PROJECT_DIR/public/inendi-inspector_flatpak.tar.bz2"
And then copy its content to the flatpak app to be stored on flathub like this :
