Is there a temporary workaround for the appstream-missing-screenshots error?
This is a similar situation to ARM build (only) fails due to missing screenshots - #5 by bbhtt but there are a couple of minor differences:
  1. Tag or Website problem? Even though I could not obtain the xml.gz file in this build because it failed due to the tag check for screenshots, I was able to obtain the xml.gz file from navigating the environment of the same flatpak compiled by Github Actions on my own github. https://github.com/user-attachments/files/20760686/org.gramps_project.Gramps.xml.txt (I added the .txt at the end to force Github to upload it while discussing this problem at the gramps-project Github, so just remove the .txt at the end to open it as an xml). There is a tag to obtain media from gramp-project.org but not specifically the <screenshots> tag. Is the build failure for Flathub due to screenshot tag method being done differently, or because the website hosting the media is blocked by Github Actions?
  2. Is there a temporary workaround until the apps metainfo generation gets changed in a future update? I suspect that if a change is made to metainfo generation by Gramps, it will be placed in a future update. I have already asked the project head about whether they are willing to change the metainfo generation and when. Is there a workaround available to update Gramps at Flathub until the Gramps metainfo generation is altered at some future point?
Here is the error:
“info”: [
"appstream-missing-screenshots: Catalogue file has no screenshots. Please check if screenshot URLs are reachable"
“message”: “Please consult the documentation at Flatpak builder lint | Flathub Documentation
Recently gramps-project put cloudflare antibot protection on the gramps-project website. Perhaps that is another possibility that caused the “appstream-missing-screenshots” error that caused the build to fail, since downloading the images could trigger an antibot question before allowing access?
It was the cloudflare antibot protection that prevented github actions from getting the screenshots. It is resolved now.
